Barham build
Discussion in 'Warship Builds' started by Maxspin, Sep 3, 2014.
  1. Maxspin
    Maxspin -->> C T D <<--
    Yelm, Washington
    Been making some progress on the Barham.
    I have been minimizing the use of wood so far. For the superstructure I have used closed cell foam covered with ABS plastic.
    As you can see I will never win "Best of Scale"
    On to the important stuff. The first Gun is mounted.
    That is one of the reasons to build a Barham!!!
    For the sidemounts I will be using the Maxspin Mark 1 cannon. I have ordered some 90 deg Push to connect fitting in order to get the air line to the cannon. I will figure out the magazine configuration after I have mounted the dual aft cannons.
  2. SteveT44
    Looking good!
  3. Maxspin
    Yelm, Washington
    I got a bad case of..... I think it's called Tuggy disease.....
    OOOoowwww look a squirrel, I mean a Komet.
    Komet is now repaired and battle ready. Like I really needed (2) convoy ships... :bang::bang::bang:
    Tugboat, NickMyers and CURT like this.
    Tuggy's disease is a burden that few truly appreciate :) Any interest in another hull for you shop? ;)
  5. Reckless
    Reckless Active Member
    Ladysmith BC
    disease? ... burden? ... no no no.... it's not that, ..... right? dont make the wives right!!!! :D
  6. irnuke
    Lookin' good Max...my only concern is how high the gun is sitting up out of the barbette. Will that fit under the turret as positioned?
  7. Maxspin
    Yelm, Washington
    I haven't cut a slot for the barrel yet, but I think it will fit.
  8. Maxspin
    Yelm, Washington
    Next ship will be VDT. Neeeeeeed hulllllll....... o_O
    no No NO! Must finish Barham :D
    Tugboat likes this.
    I think it'll fit in that turret with no drama. Easy fit.
  10. Maxspin
    Yelm, Washington
    42 pieces of balsa!
    You can see where I used ABS plastic in the casements. Local rules do not require that we make them penetrable. I can remove the ABS and replace with balsa if I ever make it to an event that requires it.
  11. irnuke
    Very nice work.
  12. GregMcFadden
    Where did you find that fitting on the cannon to solenoid connection?
  13. Maxspin
    Yelm, Washington
    Looks great!!
  15. Maxspin
    Yelm, Washington
    Brought the Barham to our battle this last weekend for sea trials. Had a little time before we got started to check float and speed. I am now to trying to figure out the firing boards, and pump switch..... Not my strong suit :mad:.
  16. GregMcFadden
    remind me and I will bring my test board to the july battle. We can then verify if the issue resides in the TX or in the switch configuration. if we can make my test board work, we can then figure out how to make your switches work the same way. I will let you know what connections will be needed to connect to my test board. they are all std. servo lead connections but I don't remember which one is male and which ones are female connections on the power side. on the RX to firing board connection, the connection is already female so it plugs right into the RX.
  17. Maxspin
    Yelm, Washington
    The solinoid's go click click click and the pump goes whizzzzzzzzz. She will be combat ready by the next battle. :D:D:D
  18. NickMyers
    Most exciting news! I shall polish my bbs for the event.
  19. absolutek
    Ahh, so maybe next year you'll come out east to back up all those "maths"of yours? ;)
  20. Maxspin
    Yelm, Washington
    Your Derfflinger is ugly and has a small......... pump!
    absolutek likes this.
