Hello from England!
Discussion in 'Introductions' started by Thewaltham, Mar 11, 2015.
  1. Thewaltham
    Thewaltham Member
    United Kingdom
    I recently found some of the videos from youtube, thought it looked interesting, so I decided to come along and join up. Doesn't seem to be any clubs in the UK, but i'm probably going to still put together a warship to the proper specifications and sail it around for the sheer hell of it.
    So far, i'm thinking using the HMS Hood for my design, any advice you can give a new captain from across the pond would be greatly appreciated.
  2. Lou
    Hello and welcome!
    First question: Wood or fiberglass hull?
  3. Thewaltham
    Thewaltham Member
    United Kingdom
    I'll probably go for fiberglass, seems like it would be easier to patch.
  4. NickMyers
    Welcome aboard!
    We don't shoot holes in the fiberglass. When we build the ships we cut 'windows' into the fiberglass hulls and cover them with balsa. The shot penetrates the balsa.
  5. Lou
    Are there any restrictions in England on BB guns?
  6. Thewaltham
    Thewaltham Member
    United Kingdom
    I don't think so, i'll have to check, and hrm, do you shoot holes in the wooden hulls then? Or is it the same deal with the balsa patches?
    *Edit*
    Realistic BB guns are only legal if you're part of a club, seeing as this BB system is just part of a mechanism on a RC boat, all good and legal provided you don't aim at people of course. Also, loving the SMS Derfflinger Nick, looks awesome.
  7. NickMyers
    Same deal. The wood framed hull is generally highly resistant to impact damage and the open windows are sheeted over with balsa. Take a look at a few of the threads in the Warship Builds subforum to get a good idea on how they're put together.
  8. Thewaltham
    Thewaltham Member
    United Kingdom
    Will do. Any recommendations on builds, etc?
  9. NickMyers
  10. Tugboat
    Yes, yes, I need to finish it.
    Welcome to the hobby, Thewaltham! If you're going to build the Hood, get the book 'The Anatomy of the Ship: The Battlecruiser Hood', it's got all the info and then some that you'll need to build an excellent model of Hood.
  11. irnuke
    Welcome aboard, Thewaltham. Hood is a strong contender (IMHO) for most beautiful warship built. It would be great to see one on the water, even just in pics!
  12. Thewaltham
    Thewaltham Member
    United Kingdom
    My thoughts exactly when I chose the Hood, beautiful vessel.
    *Edit*
    A question I forgot to ask, how viable is it to take a standard RC boat for the internals for one of these vessels?
  13. irnuke
    By "internals" I assume you mean the radio receiver, speed control (aka "ESC"), drive motor, and possibly prop? It is possible, but most likely not very viable in that your normal rc boat will have at most a 4-channel radio, 1 drive motor & ESC. Hood, even if built for fast gun rules vice big gun, will need at least a 6-channel radio (throttle, rudder, pump, 3 gun controls), two drive motors and probably two ESC's to drive them.
  14. Thewaltham
    Thewaltham Member
    United Kingdom
    Hrm, true. Also, I was thinking of mounting one of these Esky® Professional Hi-Definition CCD Exterior: Amazon.co.uk: Electronics to it, to get some images while sailing on the river, maybe even a live view from the bridge. Probably going to sail her around the canals near where I live, the current isn't too strong, besides, all the better if she can operate in slightly rougher waters.
  15. irnuke
    Keep in mind that in 1:144 scale, Hood is almost 6' (1.82 meters) long and 36 lbs (16kg). She should handle a moderate chop quite handily
  16. Thewaltham
    Thewaltham Member
    United Kingdom
    Yep, I did the calculations on size, i'm more concerned with maintaining maneuverability in choppy waters. I'm going to focus heavily on the systems to see if I can squeeze as much handling prowess as I can out of this vessel, all the better for doing evasive maneuvers, setting up moves like "crossing the T", etc, and avoiding plunging shells hitting my ammunition magazine. Is there a skype chat for this sort of thing? If not, we should make one, talking live would be even better than over a forum, and hell, would mean I could chat away on my mic while working away in my garage.
  17. SteveT44
    Yes. They basically regulate the energy level of the shot which is not an issue. The issue is the regulations covering transport and use of air weapons which would make it very difficult to store, move, or battle a warship.
    Gutted. | R/C Warship Combat
  18. NickMyers
    I would suggest seeking legal counsel or at least checking in with your local constabulary before committing to arming a ship.
  19. thegeek
    On line there is a presence of Airsoft and Paintball in the UK so there may be a way, follow the paintball route because the CO2 we use and the way we use it is very similar.
  20. Gettysburg114th
    I thought there was a group that started years ago that had to go the route of Big Gun because of an issue with BB's?
