M.V. Britannic
Discussion in 'Warship Builds' started by Lou, Oct 24, 2012.
  1. Jeromy
    Jeromy Member
    • Just ordered one be here 1/11 can't wait looks like a serious wood leveraging machine
  2. jadfer
    I am planning on it also. Thanks Lou for extending the Axis effort.
  3. Jacky Fisher
    Jacky Fisher Member
    Looking good Lou!
  4. Lou
    Thanks Ty. Going to run her for the first time this weekend, will post . Will do a lot more detail after Nats.
  5. Lou
    Anyone have a method for cutting square holes in plastic? I cannot find a plastic ladder the correct size to replicate windows...
  6. irnuke
    Depending on the type & thickness of the plastic:
    Get square "tubing" of the desired size from hobby shop, sharpen edge w/ grinder, then use as a punch
    If the plastic is too thick, possibly heat the punch and melt your windows in.
    If the windows are larger than the available metal, double up as needed. Or if the windows are significantly large, use a screwdriver tip as a chisel to punch the top, bottom, and sides of each window.
  7. DarrenScott
    Or purchase a woodcarving tool which cuts 90 degree corners.
    It will be easier if you drill first then chop out the square corners.
  8. Lou
    Thanks guys. The measurements are 1/4 wide, with a 1/8 beam between windows. Looked at 90 degree cutters, everything was too large or could deform the plastic between the windows. So, i used a small drill for each of the window corners, then a brand new exacto blade to cut out. Finished with a small file. The area I am talking about are the long promenade windows that span the length of the ship.
    Decided late last night to make a master and cast in termite armor, this way when the yammato blasts away I won't have as much to fix. Pics soon
  9. Lou
    Wow, time to resurrect this old thread with new pictures. Check back soon, we need to see a little bling on the site. :woot:
    Tugboat, Beaver and NickMyers like this.
  10. Tugboat
    Picts or it didn't happen!
  11. Lou
    Blast from the past
  12. Lou
  13. Kevin P.
    Please tell me this beast will be making the trip to Nats next year, maybe the Allies can win via campaign
  14. Lou
    Possibly, and maybe another big,fat, target
    Kevin P. likes this.
  15. Lou
  16. __Titan__
    __Titan__ Member
    Minnesota
    I know this really old but I'm wondering where you got your lifeboats, if you 3D printed it our made them yourself some way.
  17. Panzer
    Hell, MI
    https://rcwarshipcombat.com/resources/rn-steam-launches.98/
    https://rcwarshipcombat.com/resources/french-wwii-boats.52/
    https://rcwarshipcombat.com/resources/some-basic-lifeboats.22/
    https://rcwarshipcombat.com/resources/ijn-utility-boats.39/
    If you have access to a 3d printer there are several to choose from in the resources section. Mark jenks has kindly provided a plethora of small boats to choose from, as well as many other resources. The ones Lou has mite be the molded style.. Welcome to the forum and hope to see you on the water, Craig
  18. __Titan__
    __Titan__ Member
    Minnesota
    Thanks, there’s a shop near where I live that will print things, just wish I knew someone that had one though, I have paypal lol.
  19. NickMyers
    A lot of folk here have printers
    Panzer likes this.
  20. Panzer
    Hell, MI
    And several of them have been very kind to those of us who have not yet made the plunge.:woot::woot:
