Spectrum DSMX Buttons
Discussion in 'Electrical & Radio' started by Nibbles1, Jul 22, 2020.
  1. Nibbles1
    Nibbles1 Well-Known Member
    Orinda, CA
    I've seen some people put buttons on a Spectrum transmitter. How exactly do you do that. Someone in Australia replaced switches, which I'm willing to do (can't switch out right stick because I need it for turret rotation and depression).
    Thx, Sammy
  2. SnipeHunter
    Basically it's just replacing the potentiometer the gimbal with a voltage divider, it's more or less the same on every radio, the resistor values aren't super important there are a lot of combinations that work.
    in no particular order check out these links:
    https://rcwarshipcombat.com/threads/adding-spektrum-firing-buttons.407498/
    https://rcwarshipcombat.com/threads/radio-push-buttons.444055/
    https://rcwarshipcombat.com/threads/futaba-9c.444662/
    https://rcwarshipcombat.com/threads/turnigy-tgy-i6-button-modification.445803/
    https://www.scrapcombatships.com/articles/howto/BE-radiomodvg600.php
    Nibbles1 likes this.
